Evolabel Flexwipe Label Applicators - Interfacing with Rockwell Automation
Rob S.
Sep 2008
Maryland
739
Good Morning ,
We are looking at getting a Evolabel Flexwipe Label Maker . Have any of you have been involved in using these ?
I'm trying to find a good example and manual on how to interface with a Rockwell Automation ControlLogix , AOP , EDS , etc.
Would you folks have any examples ?
Thanks so much.
Good Morning ,
Thanks so much.
I see that natively it does not seem to have CIP, , although it does have Modbus TCP, as well as digital I/O, among other options.
Depending on your application, pick either or. If one fails, try getting something like this or this
Do not go with the Modbus route! No need to buy these fancy modules.
It may not have CIP, but it is TCP/IP. Use socket instead.
Any documentation for this? TCP/IP with Rockwell, as well as for the printer?
Good Afternoon , Thinking of replacing a Labeler with a brand , named EvoLabels ( Flexwipe ). Sounds like their communication is using Modbus...
1,891
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
396
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
133
Hello, My company has recently been tasked with a redesign of an HMI and they were originally using Numeric Inputs to display the values. I am...
965
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
596
