Changing nodes for Micrologix 1200 and 1500 without Teach Pendent
BradSensenig
Apr 2012
PA
18
We had a DH-485 network with a SLC 5/02, PV 550, 2 Micrologix 1200, and Mircologix 1500. I need to know how to change the nodes of the 2 1200s and 1500 using a PC - the teach pendents I have only work for ML 1000s.
Brad
teach pendents ?
Do you mean change the node addresses? If so you will need RSLogix500 software ( programming software) and RSLinx to get connected to your processors.
If you have them, then go online with the processors and look for channel configuration
under the project tree. There you can make changes.
Thank you for your response. I meant to say hand held programmer. I know there is an easy way to change node addresses with a hand held programmer for mircologix 1000s. I have the RSLogix500 software. I will try with the software.
Thank you,
Brad
We're using a 64K memory SLC 5/04 CPU. One day the program suddenly got erased from the CPU, causing the process to activate the emergency stop...
918
I currently have 2 SLC 5/04s and 2 PLC 5's on a DH+ network with various node designations. I have been working on a 3rd SLC 5/04 to automate a...
5,203
Hi, folks! First post..... My background is in Mainframe programming (20 years), but PLC programming is a whole 'nother animal, it...
6,718
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
267
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
507
