dang212
Hi everyone, I tried to use data log models in FTV Studio to store tag's value of a trend to a mdf file. Then i start my project in runtime mode, use DataLogOn to start data logging and then DataLogOff to stop data logging.
After that i tend to attach that mdf file to a SQL server using SQL server Management Studio but i can't because of this error: "filename.mdf is not a primary database file Microsoft SQL Server, Error: 5171"
And when i search about the error 5171 in Microsoft SQL, they said that the mdf file is somehow corrupted. I tested a lot of times but still face the same problem
Do you guys know about this issue, i think i missed something when i create data log models but i am not sure about that.
I am not good to explain in English so if you don't understand, i try to explain more clearly.
Thanks for reading
Thanks for reading
