FactoryTalk View ME Printing runtime displays
wesselvos
May 2016
Kaatsheuvel
21
Hiya,
Today a customer of mine requested being able to print out displays on the HMI. (Panelview Plus 6 1500)
I did a little research and added a display print button to my screen. This button however doesnt contain anything to connect to a specific printer by the looks of it.
How do i know where my print is going, how do i configure this and can i set this up to work with a network printer?
Please note that i have checked the print setup tab in my terminal settings but that comes up empty. (do i need to install a windows CE driver on my Panel?)
Thanks!
Both good idea's but im afraid its not really what im looking for. I can set it up to print screens i think by using the display print button. I dont have to do it remotely.
The problem im getting is: when i navigate to the terminal settings and then the printer setup nothing appears. I would expect to see something like a printer driver in there. How do i set a printer to print to in there?
Hello, I am trying to print a HMI display page. I've attached a .png of the display I am trying to print named "MPM_Print". I'm using VBA to...
5,111
Hi all, I need some assitance with printing display in Factorytalk. I don't want to alter PLC program since it's not done by me (don't want to...
2,039
Any thoughts on how to Print data from Factory Talk View SE? I want to print a report using live data from the PLC. I've been given a microsoft...
8,334
I have an application that reads a bit value from 5 plc's and uses an expression to compare the bits and print a display screen based on that...
7,367
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
116
