FactoryTalk View SE - Printing Displays
Sep 2018
Vancouver
Hello,
I am trying to print a HMI display page. I've attached a .png of the display I am trying to print named "MPM_Print".
I'm using VBA to execute a PrintDisplay command: (See Attached "MPM_Print VBA").
Private Sub PrintPage_Change()
If PrintPage.Value = 1 Then
ExecuteCommand "PrintDisplay MPM_Print"
End If
End Sub
I keep getting the following error:
"The command 'PrintDisplay ' is ignored when issued from the development environment or an HMI Server." (See Attached "MPM_Print Warning")
Any suggestions on how to fix this warning and get the display to print?
Cheers.
You are running this VBA script on a FTV SE Client right?
RA KB (279647 & 453253) states the command PrintDisplay will not run from Development or SE Server.
/giggle
Ignition has buttons by default to do just this for alarm and trend displays. Print the display, save it to CSV files, Email it...
/Not missing FTView SE/ME AT ALL!
Just as the warning says "The command 'PrintDisplay ' is ignored when issued from the development environment or an HMI Server."
Once I ran the client file and toggled the bit in the PLC to Print the display everything worked! (y)
Hiya, Today a customer of mine requested being able to print out displays on the HMI. (Panelview Plus 6 1500) I did a little research and added...
6,172
Hi all, I need some assitance with printing display in Factorytalk. I don't want to alter PLC program since it's not done by me (don't want to...
2,039
Any thoughts on how to Print data from Factory Talk View SE? I want to print a report using live data from the PLC. I've been given a microsoft...
8,334
I have an application that reads a bit value from 5 plc's and uses an expression to compare the bits and print a display screen based on that...
7,367
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
116
