the simple answer to your question:
if your test value is ON THE FENCE (equal to the HIGH value or equal to the LOW value) then the LIM will be TRUE ...
as expected, any value BETWEEN the HIGH and the LOW LIMITS will also be TRUE ...
going further:
suppose that your HIGH LIMIT is 10 ... and the LOW LIMIT is 20 ... (this is what I personally call a "left-handed" LIMIT) ...
in that case the rule for values BETWEEN the HIGH and the LOW LIMITS is "reversed" ... specifically, 15 (between) would be FALSE - and 25 (outside) would be TRUE ...
so - that raises the question: for a "left handed" LIMIT does the "ON THE FENCE" rule get "reversed" too? ... nope ... once again, if your test value is ON THE FENCE (either 10 or 20 in this example) then the LIM instruction will still be evaluated as TRUE ...
going even further:
in some cases a programmer will use VARIABLES for the HIGH and the LOW entries ... that's OK - but you have to be extremely careful ... suppose that the value in the HIGH entry suddenly becomes "shifted" and becomes LOWER than the LOW LIMIT value ... (or vice versa) ... oops! ... suddenly the LIMIT instruction has become "left handed" - and all of the conditions that you intended to be FALSE are now evaluated as TRUE ...
in SOME installations this could be an extremely hazardous situation ...
