RSLogix 5000 MSG Socket to Modbus-TCP
id10t_error
Oct 2017
California
99
If you click help and then click Vendor Sample Projects while in RSLogix 5000, a PDF will pop up with some neat examples. One example shows how to use a processor's serial port as a Modbus-Slave/Modbus-Master.
Is it possible to adapt the Modbus examples to talk Modbus-TCP using the RSLogix 5000 Message instruction?
Thanks for your help!
If you search the AB sample code library online there is a sample there to use just messaging to do Modbus TCP. It looks very complicated but it does work. I tried it once with a paperless chart recorder. But I ended up just using a Spectrum Controls Universal gateway as it was much simpler.
Thanks for the Responses!
The Modbus/TCP AOI needs at least version 20 with an 1756-EWEB from what I read. I have upgraded my 1756-L55 to a 1756-L63 with a 1756-ENBT. Next, I will need to replace the ENBT?
Modbus AOI should work with Ver 17 of higher.
L63 can run Ver 20.
But 1756-ENBT does not support Sockets.
You need a modern module like EN2T or old EWEB
I'm trying get information from another same PLC PLC1: CompactLogix 1769-L16ER-BB1B (192.168.0.133) PLC1: CompactLogix 1769-L16ER-BB1B...
17
1,592
Hello everyone, it is the first time that I need to exchange messages between 2 PLCs, a L16ER-BB1B and an L61. The first has 192.168.1.1 as its...
4,460
Hello, I was curious if any one could shed some light on setting up a MSG statement between two PLC's on different networks. I'm trying to read...
1,329
Hello Guys, I'm trying to set up a message instruction between two Compact Logix processors that are on the same ethernet network. All I'm...
2,443
I have a question on a subject of etherent nodes in rslogix 5000 project tree for a project that I am working on. I am trying to read if read...
4,689
