String Indirect addressing from one DB to another DB
Sreekanth
Apr 2021
Bangalore
I have one common Buffer DB 10 with multiple String values, I am trying to move from DB10 to MainDB 20 using with SFC 20 Move block not sure how to do this.🔨
It's not strictly indirect addressing but...
Call your SFC20 block.
For your SRCBLK put P#DB10.DBX0.0
Create a temp Int variable called Temp_Ret_Val and use #Temp_Ret_Val for your RET_VAL
For your destination put P#DB20.DBX0.0 BYTE 608
That should copy all the strings from DB10 into DB20
Adjust the SRC address, destination address and number of bytes depending on how many strings you want to move and where you want to move them to.
I remember a while back somebody asking about how to Indirect address a Logix tag using a string. It is possible. I just stumbled across this tech...
2,472
Hey, guys. I'm a co-op/intern at a company this semester, and I'm learning how to program PLCs. I'm using RSLogix 500 and a MicroLogix 1400 PLC to...
4,250
Is it possible to do an indirectly address copy of strings in the Micrologix 1500. I would go to the AB forum but it's being incredibly slow. I...
2,581
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
160
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
171
