Received via PM
Steve Bailey
Apr 2002
The boondocks of Western Massachusetts USA
8,591
I received this by PM. I prefer to keep the discussion on the forum.
Hello ! I managed to connect to PLC GE 90-30. I don't know the Proficy Machine program well, I think that the plc no longer has a program in it. I will attach some pictures. How can I make a Backup to another Plc that has the program and save it in the one with problems? Thank you very much ! https://drive.google.com/drive/folde...I0?usp=sharing
You are correct that there is no program in the PLC you were connected to when you took the screenshots. The program name "HHP' is the default for a blank CPU as well as the "No user program present" entries in the fault table.
Connect to a working PLC and upload the logic and configuration from it. Then connect to the one with no program and download. Be careful you don't mix up the direction of transfer. Proficy considers 'upload' to be a transfer from the PLC to the computer and 'download' to be a transfer from the computer to the PLC.
Thank you very much for the information! The car for which I need the program is an ArtFoil Graphic LR82, if anyone has the saved program and can help me?
A good day !
Were those the only files? Megabasic files have the suffix .bas You can probably get along without PCOP. Termf is sufficient to do whatever you...
179
I just got this via PM I prefer to keep the discussion on the forum. Can you be a little more specific? What is the nature of your trouble? Are...
665
I got this PM this morning. I prefer to keep the discussion on the forum. There are two default passwords in a PanelMate. I would try them...
870
I got this request today. I prefer to answer on the forum. Hello Steve, I am doing an upgrade to a PLC rack and I have an IC693CMM302 and...
925
I get this PM today. I prefer to answer in the forum in case others have similar questions. Steve, Good morning! You seem to be the resident...
1,006
