Received via PM
Steve Bailey
Apr 2002
The boondocks of Western Massachusetts USA
8,605
I got this request today. I prefer to answer on the forum.
Hello Steve,
I am doing an upgrade to a PLC rack and I have an IC693CMM302 and IC693CMM311
What is your advice concerning upgrading these modules?
What else is on the Genius network with the CMM302? What is the serial device connected to the CMM311? Need those answers to recommend the best path forward.
Genius is obsolete. Your best bet is to use a different network. Serial communications is no longer in favor. Check the hardware configuration to find out what serial protocol is in use. If it is SNPX you will need to modify whatever is on the other end of the cable to the CMM311. The Rx3i does not support SNPX (or did not the last time I checked).
Were those the only files? Megabasic files have the suffix .bas You can probably get along without PCOP. Termf is sufficient to do whatever you...
185
I received this by PM. I prefer to keep the discussion on the forum. Hello ! I managed to connect to PLC GE 90-30. I don't know the Proficy...
1,164
I just got this via PM I prefer to keep the discussion on the forum. Can you be a little more specific? What is the nature of your trouble? Are...
672
I got this PM this morning. I prefer to keep the discussion on the forum. There are two default passwords in a PanelMate. I would try them...
876
I get this PM today. I prefer to answer in the forum in case others have similar questions. Steve, Good morning! You seem to be the resident...
1,014
