wiring diagram of PLC connection cable (pin-out)
MEMO19777
Nov 2005
DAMAS
I Want to make connection cable between my PC and PLC(Hitachi), but the problem that i just have the wiring diagram of the connection cable from the PLC side and i need to know the pin-out diagram of (9pin RS232) connector from PC side.
in other words you are kindly just to help me and fill this table:
PIN No.
(PLC side)
SIGNAL ABBREVIATION
SUB-D(9)PIN No.
(PC Side RS232 Connector)
SG1
VCC (+5v)
DTR1(ER)
CD1(DCD)
SD1(TXD)
RD1(RXD)
DR1(DSR)
RS1(RTS)
Serial on a STD PC is pins 2, 3 and 5 respectively.
PC 3 TXD
PC 4 DTR
PC 2 RXD
PC 8 CTS
PC 5 GND
This is the PC side only. I have never worked with Hitachi, but they have to be the same as any other system out there. Chances are, do a cross connection to 2-3 and 5. Forget about the others at first.....or buy the damn cable.
Cable for connection PC to PLC Hitachi
PC, 9 pin, Cannon, female ............ EH-CPU, RJ45
1 (DCD), 4 (DTR), 6 (DSR) ------------- 7 (DR1)
2 (RxD) ----------------------------- 5 (SD1)
3 (TxD) ----------------------------- 6 (RD1)
5 (SG) ----------------------------- 1 (SG1)
8 (CTS) ----------------------------- 8 (RS1)
can anyone ..guid me the auto /manual switch wiring digram so that, I can use plc for auto and mnual purpose.....seperately...
4,543
Twice in two weeks now I have made a single change to a drawing set and had to update the entire drawing set. In one case it was a 23 page set...
2,795
I cannot seem to find any valuable technical document for the GE IC695ALG608 on emersons site or online. Does anyone have a tech document or...
935
Im a mechatronics instructor at a local community college. I have a couple of motor control questions and would definitely appreciate any help...
1,832
https://imgur.com/a/kKPtzyP We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC...
1,820
