danielcarter
Good day everyone! Im looking for some help with regards to the Siemens S7-400 PLC. Im a student working on a tech thesis which envolves a conveyor and robotic arm assembly. My problem is that I have the plc wired and powered up and all the hardware configured to what i think is right. Im trying to test a few components with a simple program consisting of a limit switch and solenoid. when I download the program to the plc and switch it to run mode and activate the limit switch noting happens in the step 7 program(the state of the limit switch does not change)in monitor mode and the solenoid valve does not activate. but the bit led on the card turns on (input card) nothing happens to the bit light on the output card. any ideas to what may be causing this??? I need help!
