marciofpa
Hello,
I have a problem with RSlogix5000 v.15.01.00:
When i export tags via the CSV file, the file is full of "?" character
in substitution of ";" or ",".
remark?"CSV-Import-Export"
remark?"Date = Thu Jul 27 12:06:39 2006"
remark?"Version = RSLogix 5000 v15.01"
remark?"Owner = TecnoMoageira"
remark?"Company = TecnoMoageira"
0.3
TYPE?SCOPE?NAME?DESCRIPTION?DATATYPE?SPECIFIER?ATTRIBUTES
TAG??Local:1:I?""?"AB:1769_SDN_496Bytes:I:0"?""?""
TAG??Local:1:O?""?"AB:1769_SDN_364Bytes:O:0"?""?""
TAG??Local:2:I?""?"AB:1769_DI32:I:0"?""?""
TAG??Local:3:C?""?"AB:1769_DO32:C:0"?""?""
TAG??Local:3:I?""?"AB:1769_DO32:I:0"?""?""
TAG??Local:3:O?""?"AB:1769_DO32:O:0"?""?""
TAG??Local:4:C?""?"AB:1769_IF4:C:0"?""?""
TAG??Local:4:I?""?"AB:1769_IF4:I:0"?""?""
TAG??B3?""?"INT[3]"?""?"(RADIX := Decimal)"
TAG??DataHora?""?"INT[14]"?""?"(RADIX := Decimal, PLCMappingFile := 10, IncludeConnectionStatus := No)"
TAG??Teste32Bits?""?"INT[2]"?""?"(RADIX := Decimal, PLCMappingFile := 11, IncludeConnectionStatus := No)"
TAG??Teste32bits_real?""?"DINT"?""?"(RADIX := Decimal)"
TAG??U4?""?"E3_PLUS"?""?""
TAG?MainProgram?Teste?""?"DINT"?""?"(RADIX := Decimal)"
But, simple substitution for the "," or ";", don´t solve the problem.
The error message from log window of RSLogix when i try to re-import the same file:
Importing from C:\Documents and Settings\freitas\Desktop\teste.CSV...
Options: Create Tags=Yes, Overwrite/Discard Tags=Overwrite
Import New Comments=Yes, Overwrite/Discard Comments=Overwrite, Match by Rung Number=No
Error: Line 7: CR was seen in the middle of CSV record
Error: Line 6: The CSV Schema line or Record line is invalid
Error: Line 6: Syntax error found while scanning import file.
Import aborted. All import actions have been undone and the original project content restored.
My windows is W2K SP4 Brazilian Portuguese.
My RSLogix is the English version.
Thanks in advance.
0.3
Thanks in advance.
