Serial communication with PLC5/40B
sheppawc
Nov 2006
Painted Post, NY
21
Problem communicating with PLC-5/40B. RSLinx Auto detected the PLC during processor boot-up, but then a red X was placed over the PLC-5/40B icon in RSWho. I used this cable configuration:
9-PIN Female 25-PIN Male
3-------------------------------------3
2-------------------------------------2
7-----┐ ┌---4
8-----┘ └---5
6-----┐ ┌---20
1-----│ │---6
4-----┘ └---8
5-------------------------------------7
I am trying to communicate with the following DF1 Driver parameters:
Baud = 2400
Parity = None
Stop Bits =1
Device = PLC-CH0
Station = 00
Error Checking = BCC
Protocol = Full Duplex
The DIP SW on the processor is set to RS232C
My serial port on PC is working!
Is this the correct configuration? If anyone could help, it would be great! Thanks.
Have you tried Auto Configure
Yes I did and it detected it only if I reboot the PLC processor at about the same time as I click the auto config button. The yellow Comm LED on the processor blinks on & off a few times and the the red X in RSWho goes away for a few seconds and then re-appears. I have checked the cable configuration several times and have even tried different configurations with no luck. I have also tried different dip switch settings on the processor for the rs232c.
Also if the channel is configured for something other then point to point then? RSLinx driver may have to be changed
I just bought this processor on ebay and have never connected to it and have not created any files yet. I don't even see the PLC-5 listed in RSLogix to create a new offline document.
Well then you can power down and pull the battery. This will return processor to its default settings.
Default Settings:
What RSLogix software do you have? You need RSlogix5
I had the battery out all last night with the power off, so it should be back to factory default. I have RSLogix 500 & 5000. I think I need to update the processor type: list because I can not find my processor type list in eather versions of RSLogix. I need to choose a processor before I can creat a new doc. Thank you for your help.
Yes as stated above you need RSLogix5. For the PLC5 family. But RSLinx should have made the connection.
As Mickey said, you must have RSlogix5.
RSlogix500 and 5000 will not program it.
But you can to RSlinx test:
Pull the battery, do autoconfiguration.
If RSlinx failed, then pack it and send back.
If you got it just to play, then return and get SLC instead.
At least you have software for it already.
PLC5s are expensive, even on ebay.
If you got one cheaper than SLC, then it is probably bad.
Currently,we are facing the communication go through with 422 tx+ and tx-. Mitsubishi fx5u series is used and using command rs2. But the package...
106
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,561
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,049
Hey guys, I have a problem reading weighing data from AND AD4406 with OP-05 RS-232C Relay and Control input using Rockwell PLC Micro820. I already...
946
I have a zebra barcode scanner connected to a ******* device master UP. They are connected by RS232. By checking the serial logs on the device...
1,139
