allscott
- Join Date
- Jul 2004
- Posts
- 1,332
I know this has nothing to do with PLC's and I hope Phil doesn't mind but I haven't come across a better resource than here for a variety of topics that aren't PLC related.
We are in a bit of a panic to replace a 200HP reliance DC motor that has failed catastrophically on us (commutator destroyed etc...)
I have been dealing with my trusty repair shop that I have been dealing with for years trying to get a replacement motor ASAP!!!!.
Reliance seems to have let them down. The first motor they offered to sell me was designed to be coupled rather than belt driven (which is what I need), I know enough about bearings to know that that probably wasn't a good idea.
We have determined that the original motor was way oversized and that a 150HP motor would do the job. The next motor they offered was a straight shunt 150 HP motor as opposed to the stab shunt motor that we originally had.
The motor is connected to a Siemens Simoreg drive, unfortunately I don't have the model number with me.
I know that I need to make sure that the field regulator can handle the extra current of the straight shunt motor which is about 8A as opposed to 4.2A, but other than that, should this work OK?
The application is a plastic barrell extruder where reasonably accurate speed control is necessary but the load is fairly constant once the process is up to speed.
It is now Wednesday night and I have been working with the supplier on this since Monday morning and I, as well as my boss are getting frustrated. I am not tied to Reliance, if anyone has a good source for large DC motors I would love here from them.
As always, thanks in advance
edit:
More details,
Motor is 500V DC armature, 300V DC field, 1750 RPM base speed
The drive is capable of but the process never requires operation above base speed, 1100 RPM is about average.
edit:
More details,
