Siemens S120 drive to control Lenze servomotor
Kataeb
Jan 2007
www.livelovelebanon.com
636
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo parameters . . .
Siemens CU310-2 PN 6SL3040-1LA01-0AA0 , Siemens PM240-2 6SL3210-1PE31-1AL0
Lenze motor MDFQARS112-22 with resolver IDNR00397002 , Lenze motor GFQBT112-24 with resolver IDNR00397002 (installed on or inside the motor)
A quick search and I wasn't able to find the motor or resolver specs. I have use the Siemens S120 to control other resolver based servos that have long been obsolete. For a resolve you will need a Simens SMC20 module, 6SL3055-0AA00-5AA3. I just needed the specs for the motor and I was able to enter there into the S120.
I would compare these to a Siemens 1PH7/8 motor
I dont think you would have any problem running these Lenze motors
Yours is asynchronous, thats why I believe it will work fine
Just be sure to get the correct SMC for the encoder
Dear all, I have a problem in my equipment, its a ship unloader, i face this problem each time at crane operation. When the operator closes the...
1,449
In my S120 drive I do passive homing of an axis, because the movement is continious but I could not find the exact modulus due to many chains...
6,506
Hey, i wonder what is the right way to make motor identification and rotations measurement. Going to run the driver in mode 20: vector in...
2,344
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
69
Kindly, can we install new Siemens Sinamics S120 motor modules and new 1FK7 servomotors, in place of old types ? Will the old motion control...
1,125
