(I hope I have posted this in the correct area. If not, I suppose you can smack me in the head with a large trout.)
I have a PC running RSLinx Gateway. This PC is on my private "SCADA" network (192.168.1.x).
On any PC on the private LAN, I have no problem connecting to the remote OPC server and getting live data from the DH+ Network.
In the same building I have a "corporate" network that uses public IP addressing, and I need to get PCs on that network to connect to the remote OPC server as well. And that's where I run into problems. Simply put, the OPC client will not connect.
I've opened the appropriate ports in the hardware firewall isolating the private network. I verified my NAT settings in the firewall were correct. No connection.
I temporarily inserted an "Allow everybody and his brother to connect" entry into the firewall. No connection.
I set permissions and security in DCOM to let anyone connect. No connection.
I've tried multiple OPC test clients, which give me slightly differing errors:
"Connection to the server failed. ~RSLinx OPC Server ~"
"Runtime Error '-2147022986' The object exporter specified was not found."
Error: -2147022986, Method 'Connect' of 'IOPCAutoServer' failed.
And again, the test clients work as expected on the private network, the errors only happen when I try to connect from our WAN to the server.
Does anyone have any suggestions I might try to get this up and running?
Thanks,
jep
Thanks,
jep
