conversion from S5 to S7
baidimed
Jul 2008
ariana
23
hi
i hav a problem to convert fb 250 and fb251
can u help me
:geek: (' i think that is automatically conevrted not used fc 105)
You have to put your thinking hat on.
S5 FB250/FB251 are used for scaling analog i/o.
S7 FC105/FC106 are similar but not 100% the same.
Most important, in FC105/FC106 the engineering value is a REAL whereas in FB250/FB251 it was an integer (if I remember correctly).
fb 250 and fb251 r converted automatically with fc 10 and fc11 who to get the adderss
i want to no that fb 250 and fb251 are converted to fc10 and fc11 but and thr r no logic in fc 10 and fc 11 who to use it ac a standared block, and whowe get adderss of fb 250 and fb251 (analog input and output piw ,pqw )to change in s7 progrm
as i m using encoder feed back in s5 program i have to use count in s7 who i get it
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
226
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
105
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
132
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
109
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
297
