keithkyll is right
it must be needed four diodes to make full wave rectifer if we have two wires only ( one only is a hot wire and the another is a nuetral wire ) as the same if the two wires are hot
1- but if we use two hot wires , the positive output DC is fixed positve value as 110 VDC with respect to ground at both positive half cycle and negative half cycle , and the negative output DC is fixed negative value as - 110 VDC with respect to ground at both positive half cycle and negative half cycle
while if we use only one hot wire and the second is the nuteral wire , the positive output DC is not fixed with respect to ground at both positive half cycle and negative half cycle as for the positive half cycle its voltage with respect to ground is 220 VDC , and for the negative half cycle its voltage with respect to ground is zero voltage , while the negative output DC is zero voltage with respect to ground at the positive half cycle , and the negative output DC is - 220 VDC with respect to ground at the negative half cycle
is my note correct ??
i know there is no difference if we measure the voltage between the two terminals of the DC output as - at both two cases - as the voltage between the two terminals of the output is always fixed 220 VDC and the cuurent pass into only one direction , while the difference only for measuring with respect to ground , so i repeat is my note for this difference with respect to ground correct or not ??
2- it is very wrong to connect the negative output DC to the ground at both cases ( two wire are hot & only one wire is hot and the another is nuteral ) as it makes short circuit , is not right ?? , the only method to to connect the negative output DC to the ground is to use center tapped transformer , isnot right also ??
3- if we want to grounded the negative output DC without using center tapped transformer , the only method avliable is to use Switch Mode Power Supplies (SMPS) , at this case only we can grounded the negative output DC , is not right or not ??
4- all the discussion about full wave rectifer on electeral books and all links , it consider the two wires are hot and are out of phase as used in USA as the secondry of the transformer is Delta connection and we take the two terminals at the side of winding which makes 240 VAC , as i did not find any electeral book or any link say about if there is only one hot wire as at Egypt or at Europe ,
as this is the main reason for my miss understanding the concept for the full wave rectifer as i considered - which i think it is wrong consideration now - the AC input is output of star transformer i.e : ( only one wire is hot and the another is the nuteral ) , but in fact all the discussions - as i consider now - the AC input is output of delta transformer i. e : ( the two wires are hot ) so i made this forum which is
http://www.plctalk.net/qanda/showthread.php?t=41408
to understand well how the two out of phases is called single phase , as i am trying now to understand it well
so i repeat to be sure for all the discussion about full wave rectifer on electeral books and all links , it consider only the two wires are hot and are out of phase as used in USA as the secondry of the transformer is Delta
not star transformer as it used at Egypt or at Europe , is this note correct or not ??
thanks
