How do I find an unknown IP address?
seaston_65
Nov 2008
Ontario
47
Hello all,
So the company I'm with just got the RSLogix 5000 software so I can make some changes to an existing machine.
The Machine is running a CompactLogix and I don't know the IP address it's using.
I'm search old posts, and found this one: http://www.plctalk.net/qanda/showthread.php?t=48491&highlight=Find+IP+Address
But I can't seem to find any devices when I use RSLinx.
I currently have my computers IP address set manually (to one we use to connect to a vision camera), and my network Connections tells me I'm connected, but RSLinx shows nothing.
When I set the Computer to "Obtain an IP address automatically" Network Connections faults out and can't set an IP address.
The machine was buitd by a third party company, and they all leave at 4. I like to get online tonight, rather than wait till tomorrow.
Thanks in advance
Download Wireshark from www.wireshark.org.
Plug into the switch with the CompactLogix. Start capturing with Wireshark. Cycle power to the CompactLogix.
Type the letters "arp" into the Display Filter field in Wireshark and hit Enter. You'll see the CompactLogix broadcasting its IP address upon bootup, to confirm that there are no other devices on the LAN with that IP and to populate the MACID tables of the connected switches.
There are other threads about this; search on "Wireshark" and "ARP".
Did the supplier of your machine give you a copy of the program that you can open with RSLogix 5000 from the off line file as this file has the fully documented program.
If yes then the address should be available through controller properties from your off line file.
Where is the fun in that?? we need to spend a lot of time and money doing these kind of things... or just anyone will think they can do it and we will no longer be needed :whistle:
Dear all, we have allen breadly plc compactlogix L32.i dont know the ip address of this plc.so i could not get communication with plc...
21,308
Hi, I have a device that has a static IP that is unknown on an unknown subnet. How can I find this IP using my laptop. I tried using wireshark...
27
20,250
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
96
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
133
I have tested every screen and no single screen individually has this fault pop up, but when I compile and send to the PanelView it comes up. If I...
189
