Hello, im doing a school project that controls a rockband guitar. So what i was trying to do is use my 24v off my plc output to latch two wires. Maybe im doing something wrong but heres what i did
----24v(plc output)------[voltage divider](approx 70k and 20k)*---- across the middle is 6.2v i used that running to the gate of a IRF 511 (mosfet) then connected the two leads i want to connect across the drain and source.
I dont remember exactly what resistors i used. But their around 70k and 20k and between the two i get exactly 6.2v
These two leads are ground line for a seperate circuit inside the rockband guitar, its like 2v i believe.
Will a IRF511 work for this? Right not when the 6.2v turns on and off there is no response on the drain-source connection
Kevin
Kevin
