Trouble Retaining Changes in Allen Bradley PLC after Power Cycle
Diberoma
Feb 2024
CDMX
Hi everyone.
I have an issue with an Allen Bradley PLC model 1769-L30ER. This PLC had a previous program with a different IP address but when I modify the IP address and upload a new program, the PLC saves the changes correctly. However, if it is powered off and then powered on again, the PLC does not retain the previously made changes. Instead, it reverts to the previous program and IP address. The firmware version is 28.0.11. This issue occurs whether the PLC has the SD memory installed or not, so the problem is not that the previous program is saved in the SD and loaded onto the PLC when it restarts.
Thanks in advance.
Diberoma, welcome to the forum.
When you say you change the PLC's IP settings, do you mean you change this using RS Linx?
Are you using USB interface?
Yes, that's correct. I changed the PLC's IP using RS Linx through USB, and I've also tried changing the IP through the Ethernet port. In both methods, the changes are made successfully but revert to their previous configuration when the PLC restarts.
After the new very nice update to this site I could not log in with my original password, tried to recover my account but did not recieve a email...
397
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
616
I was interested in buying several of the Personal PLC tutor courses from the PLC training store on this site (http://www.plcs.net/store.shtml)...
991
Disclaimer: English isn’t my native language, so apologize for any incoming grammatical or spelling mistake. Hello everyone. I’m trying to make...
2,123
Hi, Small issue i've really been beating myself up over today. I've been working with Panelview panels for years. Currently working on an older...
592
