Horner plc upload
bwiring
Nov 2005
mpls. mn.
66
Has anyone had problems uploading the program from a Horner Xle102 plc......I keep getting a communication timeout error. I do believe i have proper communication set up because I can switch the plc from run to idle mode from my laptop. Any help would be great!!!!
It is possible that the programmer has disabled the "Upload" function.
Not sure about the timeouts but I would suspect the above.
Try using the SD card.
Go to the system page and then select save program.
It will save the program on the card and when having issues you'll be able to reload from the card.
Haven't looked into importing the program in cScape and opening for editing but I'll take a look when I can.
Hope this helps.
Thanks for the reply.....if the program was password protected would i not be asked to enter the password at some time? Also, when i go into tools/security it does not ask me to "log-in".
Yes and yes.
In your case, as I mentioned earlier, the programmer may choose to disable the "upload" function.
The code gets downloaded but the ladder logic is not available for upload or viewing.
As you already said that you can go on-line, no need for password and can switch PLC mode, I assume this is what you deal with.
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
76
I am having a problem communicating my PLC with Drive via Modbus connection. I start by opening the port and there is no problem, but then when I...
214
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
126
I am using Cscape 9.9 service pack 8. I am writing my program as a variable based program not register based. When I try and have the output...
842
I have a Horner PLC that is reading Ascii string from a device. When the device responds, it responds with the hex value in Ascii. I need to...
2,386
