Novell network & RSLinx
James Mcquade
Oct 2007
Nashville, Tennessee area
3,683
We have an application in which we want to put a pc onto a novell network. The problem is that the pc already has AB logix 500, RSView32, and rslinx pro loaded and running.
My last pc had the same software loaded as well as novel network and one time it took 2 hours to boot (i timed it)before getting another without novell on it. The new pc works fine without novell on it.
I even have a technote from ab saying that rslinx and novell are not compatible.
Has anyone else had this problem and do any of you have any solutions to the problem?
Thanks in advance,
james
Thanks in advance,
james
Add a non-Novel network for the RS stuff or change out the RS stuff for something that does Novel, maybe Siemens or GE? ;)
Run it in a virtual machine. First try to do a P->V (physical to virtual) conversion and test everything on that virtual machine.
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
157
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
220
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
181
We are having an issue with some servers, with "Teamed NICs" is we plug one cable leg of the team into one switch and the other to another...
65
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
837
