MOV function in CX-programer
doanhieu0104
Jan 2011
Hougang
I'm studying a Ladder program, but I don't understand How different between @MOV(21) function and MOV(21) function. Could anyone let me know, please? Thanks in advance.
In Omron CX-Programmer you can use the @ symbol in front of some operands to turn them into a 1-shot
The @MOV (or any instruction with an @ in front) will execute ONCE per false-to-true transition of the input condition(s).
Example LD 0001 MOV 113 DM100 will constantly - every scan - copy the contents of address 113 to address DM100, until the input 001 goes off.
What you will get in DM100 is the value that was in 113 _just_ before the input went off.
Eg: with MOV
scan # - IN0001 - 113 - DM100
1 off 10 0 (or last saved value)
2 on 20 20
3 on 30 30
4 off 40 30
Eg: with @MOV
2 on 20 20
3 on 30 20
4 off 40 20
Hope it helps!
RT
Wooh thank RoTaTech very much, your answer is so detail, now I have understood their feature. I will not have to think a lot for them anymore
Instruction Variation and Timing
This subject is thoroughly covered in the OMRON PLC manuals.
See attached extract from W451-E1-03 CP1H CP1L Programming Manual.
I have a program that runs a CPM Pelletizer. It has shear pins that break when rocks or other debris lodge in between the rollers and die. When...
1,502
Attached is an image of rung 43 on LAD10 of our digester program. In the MOV instruction at the end of the rung, the source address is something...
3,108
Hi all, Is there a equivalent function block that do the same as MOV function in ladder? Thanks.
2,355
I encountered a digital switch and zi tried to use [DSW S D1 D2 n] where S is the head device (x), d1 (head device (Y), D2 is the device number...
1,565
First of all, i want to thank you all for all your help. We that being said, Attach is a sample of my program, i am having trouble determining...
3,886
