Exchange Data between CPU315-DP and IM151-8F CPU
RTK
Dec 2010
San Diego
18
Hello All,
I've been reading all over about exchange data from CPU315-2DP and IM151-8F CPU (ET-200s CPU).
End up what I just need to do for my application is nothing major, so I'll use:
CPU315-2DP with CP343-1 Lean (even though having only 4 connectivities and 8 S7-Connections available) it's plenty for what I need
IM151-8F CPU that will be connected straight to one of the CP343-1 lean ports.
I'll configure the FC "PUT" and "GET" only in the IM151-8F, and use the CPU315 as "serve".... just like the example shows:
https://support.automation.siemens....lib.csinfo&lang=en&objid=18610307&caller=view
Now... this is where I got stuck !
I configured the HW Config, and then when I went to the NetPro to make the S7-Connectio... I get the error that "No conectivity available..." (picture attached)!!!??!!
Do you guys have any idea what I missing out ???!!
Thanks in advance !!
PS.: I forgot to mention that both PLC's are in the same subnet mask (255.255.255.0) and their IP's are xx.xx.xx.05
xx.xx.xx.06
I've done AG_Send AG_Receive before, but as far as I know the IM151-8 isn't compatible, and the other solution would go to the TSEND and TRCV.... but seems like way to many configuration for the little that I need....
You have selected the 315-2DP CPU when setting up the connection. That means you are trying to setup the 315-2DP + CP343-1 LEAN as client and the IM151-8 as server. It should be the other way around.
Start be selecting the IM151-8, then setup a connection to the 315-2DP.
Gents, I've a Beckhoff TwinSAFE project in TwinCAT 3 where I've 2 EL6910 Safety controllers, and need to exchange data between them. So I...
863
Hi everyone, I'm currently finding ways to create variable that can be read & write between 2 Beckhoff controllers. Target to be achieved: 1) PLC...
2,323
Hello. I am trying to do some basic file operations (move file from one folder to another, rename file in the new folder etc) and usually I just...
2,199
I'm looking to exchange approx 50kb of data between an S7-1500 and a Melsec Q Series PLC. Has anyone ever done this? Is it even possible given...
1,630
Hi there, Can anyone suggest the solution to communicate between AB Compactlogix L36ERM controller(Which is having remote flex IOs over ethernet)...
3,710
