SmartGaurd 600
darren221170
Feb 2008
leeds
18
i have an inching application where i was thinking of using an allen bradley smart gaurd 600,i havent worked with them before and wondered if anyone new if it would be suitable for my application which is:- a two handed control pendant for inching.first you press both momentary push buttons (1 nc,1no on each) and let go an alarm sounds for 4 secs, if the buttons are pressed within 7 secs the machine will inch for as long as the buttons are pressed and another 7 secs would be allowed each time the machine is inched.if the 7 secs times out then the 4 secs alarm would sound again. i dont want to buy one and find i cant use it,also this is for safety so a regular plc wont do.thanks
I used the SmartGuard 600 on a pretty large application (9 slave units on Devicenet, 13 safety zones, and the program capacity of the unit was maxxed out). Overall I was satisfied with the results. It was pretty easy to configure and has run trouble-free for about a year now. The true power of the SmartGuard (and the Omron NE1A, which is identical) is that you can create networked safety over standard Devicenet hardware. If you only need a standalone unit, I think the SmartGuard might be overkill.
You may want to consider the Omron G9SP. This unit uses the same function block programming as the SmartGuard/NE1A, but is standalone and MUCH cheaper.
http://www.ia.omron.com/product/family/2937/index_fea.html
There are timing modules available in the programming, but I don't know if they would be suitable for your application. You can download a demo of the G9SP software, which includes a simulator.
http://www.sti.com/controllers/G9SP/G9SP-Configurator-Demo.zip
thanks for the link i found the simulator a great help,although im struggling to achieve what i want to do with the available function blocks,what other safety plc's are available with better funtionality at not too higher cost or could i achieve what i want to do with any hard wired safety relays/timers?
Hello, I have a set of three tanks with their own trio of Hardy 6600 series load cells. Two of them have no issues with where they are at and...
151
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
111
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
119
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
227
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
471
