600 Volt High Flex Ethernet Patch Cables
Tim Ganz
Dec 2010
Dallas, Texas
689
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too stiff and don't route well in panels and tight areas.
Does anyone have recommendations on what to use for Ethernet cables that connect to an overload relay (AB E1+ overload with a 193-ETN ethernet...
2,502
I have heard that some inspectors are requiring 600 volt rated cat 5 cable be used in MCCs. I have also heard that this cable is available but I...
4,106
What are the CSA/UL requirements when you have to run Devicenet Cables within the same Wireway as 600 Volt motor powerwires. I was under the...
10,985
Hello, I have a set of three tanks with their own trio of Hardy 6600 series load cells. Two of them have no issues with where they are at and...
147
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
114
