Help on Siemens PLC
sudheendra.r
Jan 2011
Bangalore
Hi Dear Friends,
I have to get data from a third party device into the Siemens S7 300 PLC. Now the protocol the third party device supports is Modbus RTU protocol and the PLC has a communication processor (CP 340) which supports Modbus ASCII protocol.
I am confused how to go about it. I saw a live machine working using such a method of communication. How is this possible? How can be this Modbus RTU converted into Modbus ASCII? Any ideas?
Thanks,
Sudheendra
Hi!
You will have to write your own FBs to achieve the RTU variant.
But
I mean to recall that there was a member of the forum that had made FBs for Modbus RTU master and slave to be used on CP340 (not very expensive). I tried to search but couldn't find the thread. I think it must have been less than 2 years since.
Any of you others that have a clue?
Kalle
Edit: I found the post http://www.plctalk.net/qanda/showpost.php?p=395759&postcount=7
ByteSlicer has the address www.runmode.com
The CP341 supports modbus RTU (Master and Slave), you have to buy a license from siemens for the FB library.
An alternate would be to use the Et200s expansion (if your CPU has a profibus port) and use the Serial interface module. The FB library is free for this module.
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
161
Hi, I work in a brewery in North Carolina and I need some help finding the output current for a VFD in the PLC. First off I am new to working with...
1,349
Hi,I need to build a PLC panel with a CUP & I/O cards, the panel to be communicated with a remote (500 meter away) extension module station. I...
2,565
Hello Gurus, I have started teaching myself Allen Bradley PLC with RSLgoix 500 and LogixPro with grateful and helping comments of you gurus...
4,015
I picked up a Siemens S7 1200 from a buddy and I want to start fiddling around with it to learn about PLC's. I don't want to spend a lot of bucks...
2,479
