Wonderware InTouch Indirect Tag Addressing
aiki202
Aug 2007
Pennsylvania
178
I am trying to use an indirect tag address in a Data Change script as follows:
Whenever the Number tag value changes the following script executes. The problem is that I am not getting the strTempString to populate the IndirectDevice.Name field. Note that the strTempString is being populated correctly (I verified this).
strTempString = "Device_" + Text(Number, "###" ) + "_Busy";
IndirectDevice.Name = strTempString;
IF IndirectDevice == 1 THEN
{Do something...}
ENDIF;
Any ideas?
I think that "IndirectDevice" has to be declared as an Indirect Analog.
The other issue I have found that after you get the new tag named ok that it will not have/read the data from you IO device immediatly.
Have had to put the new tag in a script that will do the action once it has new data which could be 1-2seconds later.
Hi friends !! I am a beginner to Intouch. Can anyone please guide me on Indirect Tags. Example. I have 100 motors.For 100 motors I want to...
2,851
i try to set constant value to indirect tag but it is not set i write it in button script : boaz.value=23; (boaz is an indirect real tag name )...
10,154
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
163
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
172
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
434
