ML1400 channel 2 modbus port pinout
2004sk4
May 2005
Georgia
172
I have a project which i will need to use both comm ports as modbus rtu master. I purchased a 1763-nc01 for the mini din connector(channel 0) but would like to use the 9 pin serial connector(channel 2).
thanks
Channel 2 is an ordinary RS-232 "DTE" type serial port, so you can use any ordinary serial cable.
The minimum pinout is Pin 2 (RX), Pin 3 (TX) and Pin 5 (GND).
I got the serial port to work. The problem is the application both work on channel 0 perfectly but only has issues when using channel 2. The only difference i see is channel 0 will let me change the protocol to no handshaking 485 network. but channel 2 does not have that same option.
The application is
channel 0
modbus controlled solid state relay for lighting.
19200 even 8 data bit 1 stop bit
channel 2
modbus controlled thermostats for gas heaters in the plant. adjusts the setpoint depending on if the plant is occupied.
19200 none 8 data bit 1 stop bit
Any ideas.
thanks
If channel 2 is connected to a RS485 network then you will probably have to use a RS232 to RS485 converter.
Hi! Been looking like crazy for this, it isn't stated in the manual?! Anyone knows where to get it? /Tim
1,581
Hello everyone, I have doubt regarding ports of Micrologix 1400 PLC. Channel 0 and Channel 2... Channel 0 is Rs232C or...
3,847
Hi, We want to connect a Barcode reader to Channel 0 of a ML1400, is there a specific cable we need? We have it working on Channel 2 with a...
1,619
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
523
Hi, We may of finally received out first v21 ML1400. IP address set, proceed to download standard file for our machines & at about the 80% mark...
1,455
