Hello everyone,
I'm working in a project where my client has already purchased most of the equipment, which is working on a CompaqLogix.
In some part of the project I've to read the position of an absolute encoder part number 845D-SJDZ25ANDW4, and the client purchased a High Speed Counter module to work with it 1769HSC.
Now, I've worked with absolute encoders before, but I used a regular DCInput module to read the bits in order and do some moves and converts to read the actual value.
But I've never worked with this HSC module.
I checked the manual of both (I attach the manual of the encoder, the one of the HSC can't upload because is too big, but this is the link to it http://www.google.com.mx/url?sa=t&s...7YmIDA&usg=AFQjCNHwJgBgS_QTi9S9zpjcKUje2_AcIg ), and see that the encoder uses ten pins A-K to tell position, and some others for direction, etc., but reading the 1769HSC module I see how to connect an incremental encoder and also some examples, but I haven't figured out how should I connect this absolute encoder, and how to read the position (if it can be connected). I see a A0-, B0-, Z0-, A0+, B0+, Z0+, A1- B1- Z1-, A1+ B1+ and Z1+, I don't know if I can connect the encoder to this inputs and read all the bits like a regular DCInput module.
So, I was hoping you guys could help me.
Best regards, and hope to hear from you.
Juan
Juan
