Export/copy WinCC flexible project from Simatic
eibe
Jan 2012
Bergen
22
Hello.
does anyone know how I can export my HMI project (in this case an MP277) from SIMATIC manager, so I can open it with WinCC flexible 2008 only?
I have integrated my HMI in a step 7 project, but now I want to remove it from here an use only wincc flexible. I can see there's an "copy from step 7" option in the "project" menu in Wincc, but it's always "grey" so that I cannot choose it...
When I open an integrated project the Copy from Step 7 becomes active.
This functions as a "Save As".
That's one way.
Another way would be to look for it in Windows Explorer.
Project name > HmiEs > Project_x
If you have several HMI's in the same project, it will take a bit of searching to get the correct one as the HMI's will be named Project_1 to Project_x
If you have only one, then you'll only have Project_1
Copy this folder to another location and Open/Save the .hmi
Hey everybody, I have a bunch of bits used for diagnostics all compiled into a couple of DINTS. I have an x-ref sheet in Excel that aligns...
1,875
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
114
Hello, Does anyone know how to export the EDD files for a device in DeltaV Explorer 12.3? I can export the .fhx, but I have no idea how to get...
134
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
85
Hello to all, Is it possible to export Codesys symbols to .txt, .csv or .xml in a similar manner like exporting symbol table in STEP 7? For...
135
