InTouch 2014 Export
Apr 2024
USA
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export button is greyed out, is there any solution for this?
I tried just grabbing the files and doing a standalone transfer and it will import into InTouch 2020, but I cannot open up Windowmaker.
Any ideas?
Not sure I'm following. You have a 2014 application and you want to convert it to 2020? Just open the 2014 app in 2020 and it will convert it for you. Sounds like maybe that was your second attempt, but windowmaker wouldn't open? Any error in a popup or in the SMC logs?
Hi Everyone I had to replace an HMI & the project Intouch 7.11 was converted to Intouch 2014 R2 SP1 version. The PLC is TSX Premium. Installed...
978
Hi We have a project that is based on an AB 1769-L33ER and I need to connect this to our InTouch 2014 Scada system. We have installed the latest...
2,416
I am going to upgrade a legacy 7.11 project to Wonderware 2014. I already bought the license from Wonderware North. I was just wondering if...
2,161
Hi all. I have 3 computers using Intouch 2014R2. I just copy aaPKG back up from engineer console and import to other operator consoles. I met some...
1,275
Can anyone guide me the procedure of S7-1200 CPU and InTouch 2014 R2 Sp1 communication over TCP/IP protocol THANKS AND REGARDS MANASI
2,685
