Andreik
Good day,
I have a little problem with my Stepper Motor and PLC. From the attached image, The Pulse signal for Stepper Motor is 5VDC. However, My "COMMON" in PLC Output is -24VDC which covers Pulse and ordinary Output signals.
According to the attached excerpt from Keyence Manual, 24VDC Power Supply can be used but a current limiting Resistor should be implemented.
I'd like to know if it is possible to give +5VDC to CW+/CCW+ and -24VDC to CW-/CCW- as I indicated on my diagram.
Thank you very much,
Andrei K.
Andrei K.
