Hello all,
I'm working with an s7-1200 and a stepper motor in Tia portal v17.
This stepper motor is an SMD23E2 and I am attempting to connect this motor and an HMI to the s7-1200 with a profinet connection.
I downloaded a motor control program to the PLC but after loading it doesn't seem to be connecting or communicating with the motor at all.
I have the IP address for the motor in my project as 192.168.0.50, which is the default motor address and has not been changed, so I don't know why it isn't connecting. I currently have the PLC, HMI, and motor all plugged into an ethernet switch, with everything powered.
Under "Devices and Networks" I have a profinet connection running between the plc, motor, and hmi, and I have the proper gsdml files installed to recognize the motor. Is there something I'm forgetting to do?
Under Local Modules and Distributed I/O it says there is an error with a lower-level component, saying the smd23x2 is unreachable.
