bigbuckaroo
First off title is lacking some key information but I did not know how to word it well but hopefully I can explain it. I have an AB 5/04 with a standard PanelView on a DH+ network that goes back to a Contrologix gateway rack utlilizing a 1756-ENBT card and a 1756-DHRIO card. This is attached to the PLC network of which the Controllogix L61 processor also resides along with it's associated PanelView Plus. In the 5/04 there is memory allocated to store user inputted vessel product names. There are 7 vessels where the corrosponding names are store in the following locations: Vessel 1 N13:10 to N13:14. Vessel 2 N13:15 to N13:19. Vessel 3 N13:20 to N13:24. Vessel 4 N:13:25 to N13:29. Vessel 5 N13:30 to N13:34. Vessel 6 N13:35 to N13:39 and Vessel 7 N13:40 to N13:44. Now obviously these are interger files but when you open the data file and change the Radix to ASCII you now have the product names. What I would like to do is send that information to the L61 processor and PV+ and ultimately use that information for product routing verification. Can someone help me down this path to get those memory locations to show up as strings on the other end? I am assuming I will have to set up a message read between the two but could use some help from there. If more information is needed let me know and I will provide. Thanks in advance
