dmargineau
Well, so there actually are product name strings within the SLC/PV system.
Look into the Data Files folder of the RSLogix 500 application file; are there any ST:x data files?
If not, they are probably stored on the HMI terminal as HMI Memory Tags.
You could "retrieve" these and then MSG to the CLX system or try following Ken's path; I tend to literally believe an instruction's description instead of testing it first...
"The DTOS instruction produces the ASCII representation of a value."
...I would've stated more like :...transforms DINT, INT, REAL values into a String...
