Lenze Drive PLC Developer Studio
pacak
Sep 2006
Arad
65
Hello!
I'm trying to connect to a Lenze EPL 10200 with DDS 2.1, but do not know how to set the communication parameters.
The PLC has a Lecom A/B module and is networked with two more 9300 drives, also with Lecom modules. I can connect to these through the RS232 port on the Lecom, using Global Drive Control. However, when I try to Login to the PLC with DDS, I get a communication error message (#0).
In the Online menu, at the Communication Parameters I do not see anything about RS232.
Your help is welcomed!
Regards,
Attila
I think it is impossible to program a DrivePLC via LECOM, you will need to connect directly to the CAN system bus, using either a 2173 (serial), 2177 (usb) or 2180 (ethernet) module.
Thanks Noli2!
I could not find anything in the docs about connecting to Drive PLC trough Lecom, neither.
Does that mean that the Lecom is on the PLC only for connecting it to the other two 9300 drives?
BR
Attila
Thanks Noli2!
BR
Attila
I guess, maybe the PLC is the master and it's sending commands to the 2 9300.
Hi all, I now need to wrestle with a Lenze Servo Drive 93xx and the PLC within it. I have Global Drive Control & Global Drive PLC Developer...
2,407
Hi there, Anybody know of a uk stockist of Lenze developer studio software? I need to make a program backup from a PLC EC030(?) so if anybody...
4,108
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
239
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
185
I have an issue after programming a Lenze 8200 Vector drive using Lenze Global DRive Easy software. I have connected using a Can Bus interface...
597
