Studio 5000 Ver. 21.00 vs 21.03
KEN_KACEL
Nov 2002
NORTH COUNTRY
162
I rev'd my studio5000 form 21.00.03 to 21.03 and now I cannot down rev to 21.00.03. This is what the customer has. The processor firmware is 21.11 and I cannot upload form the PLC into 21.00.03. Tech support said I can never go back. Use extreme cation when upgrading Studio5000 minor revs, there is no uploading out of the processor.o_Oo_O
Yes this is in a TN somewhere. It has to do with Rockwell updating the security features of ver. 21. I *think* it also affects ver. 20 versions as well.
Yet for some reason, clients keep requesting this brutal hardware........
Yeah, it is silly, and ultimately makes NO sense. Consider this: How has your Ladder changes since the SLC 5 days? Probably very little? Maybe you use some AOIs and UDTs, but that is really only a function of the programming software, and nothing to do with the base level that the PLC processes at... XIO, XIC, LD....
But it's a moot point.
They have their business model, and it makes them a lot of money.
Recommend to your future clients:
Mitsubishi will take your old code and write it in to a mitsubishi PLC Free of charge.
Their software is backwards compatible (I just troubleshot a PLC that was 16 years old using the exact same installation that I am programming PLCs for today)
Their hardware is about 50% of the price on average.
Their manuals are way more in depth, and available Free of charge
Their tech support is 24/7 and available Free of charge because they get fewer calls about "Why does version 21.03 not work with 21.00.03?" because that's a business play, not an industry requirement.
I've heard that Siemens is much the same way?
This is a very specific case and is not directly related to Studio5000. As jkerekes stated this affects V20 also. Rockwell changed the way they handle code locks on a fundamental level. So once you go up there is no going back.
I really have no issue with this at a base level. If you provide a specific function you should make sure it works correctly. But I would say that the V20 install should have both V20.01 and V20.03 in the install with a HUGE warning that once you go to V20.03 you fornicate yourself going backward. I haven't installed V20.03 yet so I don't know for sure that isn't in there. But if its not that is my big issue with it.
And it works like it too. We worked one project here with Mitsi about two years ago. A very simple web line actually. But the customer requested servomotor control of the axes. We were just doing simple coordinated velocity control. Something I can do on at least three different platforms in my sleep, only one of which I have any real familiarity with. The base stuff didn't work. The factory guys couldn't get it to work. After two firmware changes we got something that was close to what we needed but we had to jump through so many hoops to get there the development cost completely overshadowed the hardware cost difference.
Each brand has their issues. Rockwell is cost and version control. Mitsi is it is too directed. If I wanted to control a pick-and-place robot the Mitsi stuff would have about written itself. Get off the beaten path a little and the wheels fall off.
Keith
Hmm...when I go to the software download page it's pretty obvious that it isn't compatible. v20.03 and v21.03 are enhanced security variants. It's all about addressing security. If security is a big concern in my organization I certainly would consider this version and be extremely happy that it is locked down.
Did Rockwell change something with search/replace? I copied a routine and just needed to replace "1A" with "1B" for example for all the tags in...
549
So I am working on a project and I am having problems trying to get this all to work. I had it working but lately I have been getting a fault on...
4,859
I have a laptop with RSLogix 5000 ver 20.04. I need Studio 5000 ver 33 for a project. Can I load that on this laptop without obtaining a new...
2,013
Good Evening , I purchased Studio 5000 Standard a few weeks ago . I know Studio goes down only has far has version 20. I need to go down to...
4,692
Boa Tarde galera. Alguém pode me ajudar, estou querendo ler e escrever nas strings nativas do 1783-NATR? Tenho um equipamento na rede com IP...
1,728
