widelto
My customer wants to implement a way to drive an hydraulic cylinder, this is what he got:
Module 1756-IF8 as differential input, this module is connected to a balluf transducer 0-10 VDC as cylinder position feedback. Balluf transducer is located inside the cylinder.
Module 1756-OF4 connected to a servovalve to drive hyd. cylinder.
I have not quoted because i'm not sure how to attack the problem, basically I'm thinking something similar to an example I saw the other day where they use a powerflex similar to a motion device. My idea is to create an AOI(s) to handle movements, similar to motion control instructions.
He wants to change speed, accel, decel and position of cylinder.
I do not want any program or something similar, I want some ideas on how to try to attack the problem in order to make an initial quotation.
Normally I would use a 1756-Hyd2 as a solution, but He has this two modules and wants to use them, they were used in the original design from Rockwell in 2004. I designed the rest of the software for the machine and now we're using and ON/OFF hydraulic valve to drive cylinder and use limit switches to indicate position.
I'm using Rslogix 5k, version 19, my cpu is 1756-L63.
Regards,
william
Regards,
william
