0-10 VDC to 4-20 ma
jimtech67
Jun 2002
New Jersey
507
I am looking for a cheap module to convert
0-10 VCD to 0 - 20 ma. I have found some but I would appreciate some input from others that have used them.
GO JETS
Wide right Can you f%$#ing believe it !!!!!!!!!!! The pain
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
439
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
121
I have a conundrum with this current circuit. I have a Siemens 1215C AC/DC/Relay and an old drive - Ratiotrol (now Boston Gear company I...
1,193
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,174
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,660
