1 Panelview with 2 PLCs
kbradray
Jan 2006
Columbia
175
I have a question about using 1 panelview with 2 PLCs.
First my setup:
PLC1=SLC 5/05 IP address 192.168.2.100
PanelView= IP address 192.168.2.101
PLC2=ML1100 IP address 192.168.2.102
The PLC1 and Panelview are already being used. The shortcut for all the existing panelview screens is called C0840 and is pointed to PLC1 at the above IP address.
Existing panelview pushbutton example: {::[C0840]B3:6/0}
I want to add PLC2 on the network and use the existing panelview to control some I/O in it. Is it as easy as creating the new screens and creating another shortcut pointing to the IP address of PLC2 called C0841 and then using the new panelview buttons in the following address: {::[C0841]B3:6/0}
Ken
I was looking for reference, and found this thread http://www.plctalk.net/qanda/showthread.php?t=117141&highlight=multiple+plc+panelview about...
3,003
A while back I submitted the following post: I have an application with two PanelView Plus 7 devices with each one talking to its own PLC. The...
22
12,301
Hello, I am working with a PLC MicroLogic 1500. I used a mechanical switch (ON/OFF) to start/stop measurements by using Input I:0/0. It works...
2,168
Hey guys, there is a long time that I just read posts here and never write, so it is the time now for that! The company I work for have around 52...
2,256
97
