120V Motor Panel
Rson
Jun 2017
Michigan
521
Question for those panel builders. I'm not a UL shop, but I usually keep my designs UL friendly in case they need to be certified (happens often).
I have a project for a single 1/2 HP motor, and the customer has requested 120V Single phase only. Fair enough, they make VFDs that will take 120V single phase in for the three phase motor. (yes, it will be a three phase motor, not a single phase)
My question is - do I have to use a UL98/489 disconnect? All of the circuit breakers & fuse blocks seem to be three pole only (or 480/240 rated). I don't see anything with SCCR documentation at 120V.
Can I just use a UL 98 non-fused disconnect and supplemental protection for this panel? I assume I still need to keep the door interlock
Hi Every One, Just want to make sure i am doing this the same way as every one else. For 120v AC motors (5 amps) are you using starters or...
2,560
I want a PLC to know when a 120v switch is turned on that powers an exhaust fan. I need to know what kind of relay would work and how i can tie...
926
Alright guys/Gals I have a good 1 for you, i have a industrial fan 5hp 120/230v i want to put a VFD on it how ever the only input voltage that...
2,241
Hello, There was a mix up in information on some redeployed equipment and two of the micro 1400's that came in were hooked to 120v when they...
1,983
I'm not sure the best way to do this. I've got an old GE plc with only 120V relay outputs. I'm replacing a UV light component with an LED...
1,900
