150-C19NBR Dip Switches
R-110
Apr 2020
Detroit Area
Hello all,
I have a client that possibly damaged their motor by physically freeing it from being frozen, but we are going down the list of other possibilities first. The two other possibilities are the fuses from the 3-Phase power lines, or the dip switch setting on the SMC-3 soft starter. Model number in description, I cannot find any documents pertaining to these dip switches. Please let me know if you know where to find them. For some reason I couldn't find them on AB's website. Thank you for your time.
What's you definition of frozen
I am guessing it that cold where you are so the motor is locked up corrosion or bad bearings
if that's the case then just replace the motor before you do anything
I'd assume ice locked it up, I'm in Michigan and their in Nebraska, apparently they've had the skid for at least a year now and it never got ran. Thank you very much to Ken for supplying that install sheet. We now think that its just as simple as changing the 6th sequence from "up to speed" to "normal". I'd assume this function just waits until its completely up to speed before it seals in the motor contacts? We never instructed them to hold the start button! Oh well, if that's the case then we all can have an early weekend by my accord. (I wish)
I need to purchase a few Large soft starters for our plant and we prefer to stay Rockwell. We have purchased SMC Flex 150 in the past and they...
273
Hi, I want to start 150 SMC Flex from Studio 5000. I have the AOP and P SMC flex AOI imported in my program. I have also set the logic mask to...
343
I have a conundrum with this current circuit. I have a Siemens 1215C AC/DC/Relay and an old drive - Ratiotrol (now Boston Gear company I...
1,191
How can I get a schematic for it? I am unable to communicate to it using PCIS with a 486 PC and suspect the SLC150 to be faulty (found in a junk...
3,137
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,169
