150-SMC-Flex : Help
Jun 2005
54
Hello Friends,
I am using about 30 number of 150-SMC-Flex devices on DeviceNet with 20-COMM-D Series-B module. I have installed the modules and the LEDs PORT/MOD/NET-A are steady Green. I have programmed the 150-SMC-Flex for Soft Start and Soft Stop Parameters. I am trying to give DeviceNet Out Signal to start the motor connected to 150-SMC-Flex.
For this Motor to start I have enabled Logic Command bit 1 to ON State.
In my PLC program, controller tags:
Comm_Rack_DeviceNet:2:O.Data[0] to Comm_Rack_DeviceNet:2:O.Data[4] are mapped for DNET Node Output and
Comm_Rack_DeviceNet:2:I.Data[0] to Comm_Rack_DeviceNet:2:I.Data[4] are mapped for DNET Node Input.
By this mapping, my plc logic makes bit Comm_Rack_DeviceNet:2:O.Data[0].1 == ON making sure that Comm_Rack_DeviceNet:2:O.Data[0].0 == OFF, Comm_Rack_DeviceNet:2:O.Data[0].8 == OFF, Comm_Rack_DeviceNet:2:O.Data[0].9 == OFF.
For some reason the motor is not getting started and the 150-SMC-Flex LEDs remain Steady Green and LCD displays "Stopped".
Am I missing anything? Please help me to rectify this issue. I appreciate your any help in advance!
Best Regards,
Pramod
Hi, I want to start 150 SMC Flex from Studio 5000. I have the AOP and P SMC flex AOI imported in my program. I have also set the logic mask to...
312
Hey When i am adding 150 smc flex to the project, i need to change "Drive Rating", what is drive rating? I tried with help but still, cant...
1,570
Hello, I would like to start the SMC without load. How can I desactivate the fault 40 : no load thank you for answer
4,360
Hi All, I have an Allen Bradley 150 SMC Flex that I need some help with. I have it set up with a 20-COMM-E card over ethernet back to my...
4,962
I have a conundrum with this current circuit. I have a Siemens 1215C AC/DC/Relay and an old drive - Ratiotrol (now Boston Gear company I...
1,174
