1747-PIC/Windows XP Problem
FSPT_Tech
Jan 2007
Compton, CA
42
Does anyone know if there is some unrepairable conflict problem using a PIC box (1747-PIC) with Windows XP? I can't communicate at all using the PIC box. I contacted AB tech support and they said there is indeed some conflict issues. Is the PIC box useless if I'm using Windows XP? I know I can still use the USB-to-DH485 converter ([size=-1]1747-UIC) as an alternative but does that mean that there is no possible way to use the PIC box with Windows XP ever again?
Thanks.
[/size]
hello, how do i get the 1747 PIC to work in RSlinx (2.42) using Windows XP (Home)?
3,981
Will the 1747-pic driver work with windows xp? We have a cpu fault on a 1747-l40a and I need to upload the program. When I configure the pic it...
6,030
I am having windows XP on laptop. it has a serial port. I am using RSLinx 2.30. I am not able to see the PIC driver in driver list during...
8,018
good afternoon all I had to pull out the old 1747-pic module my question it has a 25 pin connection I need to go to a 9 pin connection do pin 2...
1,604
Im getting trouble with my plc using 1747 pic connection, i found this solution: http://www.plctalk.net/qanda/archive/index.php/t-63919.html, but...
2,266
