1747-SDN Error Code in PLC
dipan
Jan 2016
Charlotte, NC
Morning fellas,
Anyone know if it's possible to receive the error codes displayed on 1747-SDN modules in a SLC 5/05 PLC?
I've looked through the manual and looked around in RSNetworx but there doesn't seem to be any indication that it is possible. Trying to allow non-electrical folks to see which node may have a DeviceNet fault without them having to open up an electrical cabinet.
The SLC-500 scanner only showed you the current Node and Code that are scrolling across the display, so you will have to come up with some logic to put the Codes into a data table, and to zero them out when the associated slave fault bit goes back to normal.
The ControlLogix and CompactLogix DNet scanners had more data available via their faster and bigger backplanes, so they gave you a SINT[64] array of status information for each possible slave address.
One of our running machine's DeviceNet Module (1747-SDN) had malfunctioned. So, we replaced it with a new one from spares. We maintained the...
3,057
Have you ever seen error code 88 on a 1747-SDN DeviceNet scanner? Error 88: Description: The connection choices (polled, strobed) between the...
1,608
Hi everyone, first time posting here. I have a problem with 1747-SDN devicenet scanner, connected to 3 Numatics G2-2 valve modules. We had a...
4,331
Hi forum readers. I am new to this forum and hope some of the knowledgable indiviuals can help me to resolve an issue. I am recommisions a new...
2,813
Hello, I have a CDN 066 which is connected to the 1747 SDN via the 1770 KFD to send and receive message. After configuring the scanlist of the...
4,914
