1747-uic
Purslant
Aug 2013
Waco
I have a 1747-UIC usb to DH485 interface converter.
My laptop has windows 7 64 bit.
The driver installed with RSLinx with not work with the OS.
Is there another driver for this that will work with this OS
and if so where can I download from.
I want to use the interface to communicate with a SLC5/3 via it's DH485 port, to keep the RS232 port free to communicate with an HMI.
Thanks.
Thanks, after posting my thread, looked at some other threads, and found my answer. I have everything working now.
Thanks again.
Care to share what that answer is?
The way I do it... 2 ways
1st easiest way, plug in the UIC and let W7 or W8 search the internet for the most compatible driver, this works 95% of the time, SOME PC's will search very fast (2sec then says cant find), when this happens there are not the correct permissions OR you don't have a valid Internet connection
2nd install the drivers manually, download and install the drivers below, http://www.ftdichip.com/Drivers/CDM/CDM 2.08.30 WHQL Certified.zip
This is also when you are running RSLogix directly on your machine not a virtual, if you are running VM or XP Mode then just use AB's drivers
This is also with my cable, I have not tried it on AB's yet but I think it will be the same as I can use their drivers for my cable
Also.. if you are using a 64 bit machine then you will need to use the DF1 driver because the latest RSLinx (that I have) does not have the UIC driver, see here for the setup http://www.youtube.com/watch?v=uWgu1jdAPkE
Hi all I am working with a SLC 5/02 and having trouble getting online with it. I am using a 1747-UIC adaptor which allows for USB>serial and...
85
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
415
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,309
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,455
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,266
