1756-DNB card going IDLE
casistoica
Apr 2012
kitchener
hey!
I have this 1756-DNB card going IDLE for 2-3 seconds and then back to run. It happens every 15 minutes or so...The only thing we've noticed when it happens is that the bit: StatusRegister.Run goes off and StatusRegister.DeviceFailure goes on. We have only 4 PoweFlex 40s on the network and we changed the devicenet modules on all of them and the devicenet card, so far with no luck.
Any ideas?
thanks!
Do you have the correct terminating resistors on each end of the network, if so check all your connections.
Is this a system that was working OK and is now playing up or is it a new system that you are commissioning.
Alan.
thanks for your reply!
it's an old system that has worked well for years, that's why we don't understand how it just started happening all of a sudden...
we also checked all connections and it's all ok
Hello, I installed a brand new 1756-DNB card and I proceeded to set the node address. To do this, I pressed and held down the manual config button...
2,135
Hi good day PLC Talk Community. Can somebody please shed light on 1756-DNB Diagnotic Counters and what they mean. DNB Scanner Diagnostic...
581
Hello, PLCS.net guys. Currently I'm making the safety communication on 1756-DNB to DX200 Yaskawa contoller. I made the setting and assigned the...
629
Numatics devicenet module G2-2 is replaced with new unit and address is configured from address 63 to address 1. Encountered error E#77 for Node 1...
1,039
Hi everybody, I have with me the following: 1. 1756-L73S controller + 55L7SP safety partner 2. 1756-ENBT 3. 1756-DNB 3a. 1791DS-IB8XOB8 3b...
2,256
